Question about Samsung SCX 4521F All-In-One Laser Printer
How to set fax confirmation on Samsung SCX-4521F
How do I set my fax Samsung SCX-4521F to give me a confirmation when my fax has been successfully sent? Thanks!
Posted by rickleta on
Thomas F. Schneider
  • 2,715 Answers
How do I set the fax confirmation with image on a Samsung SCX4521f multifunction printer
Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
MSG Confirm
You can set your machine to print a report showing
whether a transmission was successful, how many
pages were sent, and more. The available options are
On, Off, and On-Err, which prints only when a
transmission is not successful.
Image TCR
You can prevent the Image TCR from being included in
the confirmation report for privacy or security
protection. The available options are On or Off.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear
Jan 21, 2015 | Samsung SCX 4521F All-In-One Laser Printer
My all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting...
my all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting of the same. Thanks
Jul 09, 2011 | Samsung SCX 4521F All-In-One Laser Printer
1. I lost my driver CD, now I hardly search for free download Driver Software for Samsung SCX-4521F monochrome laser. 2. I need to send Fax documents direct from my PC through SmarThu.com....
You can download the drivers/User Manual from the Samsung Official Support site. Here is the link for Samsung SCX-4521F. Click Manual, download and refer to Section 7, Page 38 onwards for detailed instruction about setting up fax. Also you can click Drivers, select Operating System and get the drivers/ software
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Mar 19, 2011 | Samsung Office Equipment & Supplies
How to send fax in samsung scx-4521f
The SAMSUNG SCX-4521F is an efficient fax. It also has the ability to send a fax document directly from your PC via the supplied SmarThru 4 software.
Save time and paper by simply clicking on the ''PC Fax'' button from your computer.
Nov 15, 2010 | Samsung SCX 4521F All-In-One Laser Printer
We have a Samsung SCX-4521F All-in-one which has
Good Day Sir, You can troubleshoot your machine by using service manual including Fax problems. click the link below to download your manual.
Manual
Good Luck and God bless.
Jun 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Scx-4521f fax not sending and not receiving
4521f printer fax receive but not print so whats your problem
so plz solve this problem
Mar 25, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I am not receiving my faxes
I think you have to set after how many rings the SCX -4521F needs to receive the fax.
Mar 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
1,121 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
