Question about Insignia Pilot MP3 Player
I plug the device in, but it won't sync
I have loaded onto this device many times before, but this time it won't "connect" to my dell. Everytime I go to recharge the device, it erases all the songs so I have to recharge using my Imac because it isn't compatible and so can't communicate, just charge. Having figured a round about way of recharging, I was trying to reload but not it won't sync with the Dell. What do I do, and please answer in VERY SIMPLE TERMS, YOU ARE DEALING WITH AN OLDER WOMAN WHO KNOWS SQUAT ABOUT COMPUTERS. Thank you for any help you can offer.
Posted by sos_inc on
Anonymous
    New Friend:
I can't recording with insignia NS-4V24
Posted on Dec 11, 2009
Connection problem on vigo tablet
Not a solution, but... we could not connect to Vodafone, as the Vigo was not compatable with our Vodafone supplied Huawai modem!!!!!
Dec 27, 2012 | Tablets & eReaders
My Dell 2400 refuses to load windows xp
restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope this helps you
Oct 31, 2011 | Dell Computers & Internet
I cannot format dell 780 what is the solutions?
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Mar 31, 2011 | Computers & Internet
I have a 20g dj dell player that I really love. However, I can no longer get it to turn on. Everytime I plug it up to charge, the blue light comes on monentarily and then goes off. It comes on and then...
The lithium battery has no more charge. The batteries used in these sort of devices years ago can only be recharged about 500 times. You can see the exact number in the user manual. Just buy a new battery, shipping should take about 10-12 weeks
Dec 08, 2010 | Dell DJ MP3 Player
Can't save id/password
This is probably a setting in your browser. For instance, in Internet Explorer, you can set it to erase your history and other information everytime you close your browser. This would erase your saved passwords causing you to have to enter them everytime you open your browser again. If you are using Internet Explorer, go to Tools, Internet Options, and see if you have any settings to delete your information on exit. If so, uncheck this option and see if that fixes your problem.
Jul 21, 2010 | Dell Computers & Internet
App error 200
Well first of all you can try the following -
The "APP Error 200 Reset" indicates that your device firmware needs to be erased and reloaded. To perform these tasks please follow these steps:
1. Connect the BlackBerry smartphone to the computer.
2. Open BlackBerry Desktop Manager.
3. Double-click Application Loader. The Application Loader Wizard appears. You may need to unplug and re-attach the USB cable to the BlackBerry smartphone at this point for it to be recognized by Application Loader.
4. Click Next.
5. Choose the port that the BlackBerry smartphone is connected to and click Next.
6. If prompted, type the BlackBerry smartphone password and click Next.
7. The Device Application Selection screen appears. Select the applications to be loaded onto your BlackBerry smartphone.
8. If the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry smartphone. Click Next.
9. Click Next. The Completing the Application Wizard screen appears, displaying all the software that will be loaded to your BlackBerry smartphone.
10. Click the Advanced button and make sure that Erase all application data and Erase all currently installed applications are both selected. Note: If the Application Loader is not able to access all of the BlackBerry smartphone data, then both Erase all application data and Erase all currently installed applications will be grayed out.
11. Click Next, and then click Next again.
12. Click Finish. The BlackBerry Device Software is now loaded on the BlackBerry smartphone. Do not disconnect the BlackBerry smartphone until the process has completed.
Post comments for further help or information.........
Good Luck!!
Mar 26, 2010 | Cell Phones
Blackbeery 7290 every time I turn the radio on it reboots why?
Cause Summary of Causes
  1. The wireless transceiver software was not loaded onto the BlackBerry device correctly.
  2. There is a wireless transceiver hardware failure.
Cause 1
Resolution
Re-install the BlackBerry Device Software using BlackBerry Application Loader.
  1. Connect the BlackBerry device to your computer.
  2. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next.
  3. If prompted, enter your BlackBerry device password and clickNext.
  4. The Application Loader Wizard examines your BlackBerry device’s current configuration. When it is finished, the Application Selection window appears.
  5. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears.
  6. Do not click Finish. Click Advanced to begin loading the applications.
  7. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext.
  8. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete.
  9. Click Finish to begin the BlackBerry Application Loader process.
  10. Click Close when the loading operation is complete.
Cause 2
Resolution
Contact your service provider for more information.
Mar 02, 2009 | RIM BlackBerry 7290
Erase
connect it to your comupter. windows will recognise it as an extra drive. Right click it and then click format, in format check the quick format box and you should be done in less than a minute
Aug 21, 2008 | SanDisk Sansa m250 MP3 Player
Load Micro onto MP3 insignia
if you can't erase the External Memery trough the device try it though the PC
Aug 16, 2008 | Insignia NS-DV2G MP3 Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 21, 2008 | Disney Mix Max Digital Media Player
Insignia Pilot MP3 Player Logo
190 people viewed this question
Top Insignia Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
