Question about Printronix Line Matrix P5010 Printer
15 Volt CTL fail
Dear Sir,
we have a Printronix P5010 Line printer. But there is an error which we could not solve. On the screen it says" 15 Volt CTL fail". as we understood he problem is with the flash memory. Please can you help us out with the problem. do you have a software for the flash memory?
Regards
Serap Samli
Posted by serap on
  • 3 more comments
  • serap Mar 27, 2009
    after opening the sistem it says "testing hardware" then "diagnostic passed".
    after that "15 volt CTL fail" message. an the online light is flashing.
    The expert GURU has given some advice but we already have tried them before, it didn't change. Please can you give other slutions.
    until now I have no solution from you.The solutions given till now, are the troubleshootings we already have done before we have contact you. Please contact me if you have a specific solution for my problem.
    (we think that we can solve this problem with 202417-001 flash 1mx32 rom software update. But we dont know how we can get this software. please can you help about this.)
    thanks
    I think there is no solution for our problem. Untill now we couldn't come any further.
    please can you tell me where I can find "Flash software"?
    If I need to redownload it I first have to find it.
    Thanks
  • Anonymous Mar 15, 2014
    15V CTL FAIL P7005 Printer
Ho Duy
    New Friend:
Board supply error
Posted on Apr 07, 2015
Anonymous
    New Friend:
Only controller board connector unplug and plug and your printronix working normally 100% solution if connector lose change with new one ok remember if lose other wise only unplug and plug please power off condition do this work regards , rana jee
Posted on Nov 17, 2009
Arjun Komath
  • 1,170 Answers
Here are the list of possible errors and resolutions :
1 = Ribbon Drive (Right)
Possible Error Messages = 15V CTL FAIL, RIBBON STALL, RIBBON DRIVE
Drives Right Ribbon Motor (154071-901) via Ribbon Motor Extension Cable Assy (154067-901)
into connector P107 on the CMX board. Alternates drive and drag roles when the ribbon reaches
turnaround.
a) Check resistance on the motor (P107 pins 2, 4 and 6, 8 = 7.2 to 8.8ω).
b) Check continuity on the Extension Cable to verify that no opens or shorts are present.
c) Check for binding on the motor shaft or obstruction in the ribbon path causing excessive load.
2 = Ribbon Drive (Left)
Drives Left Ribbon Motor (154071-901) via Ribbon Motor Extension Cable Assy (154067-901)
into connector P106 on the CMX board. Alternates drive and drag roles when the ribbon
reaches turnaround.
a) Check resistance on the motor (P106 pins 2, 4 and 6, 8 = 7.2 to 8.8ω).
3 = +15V Regulator
Possible Error Messages = 15V CTL FAIL, CTL VOLT FAIL, RIBBON DRIVE,
TABLE MISMATCH
+15 Voltage Regulator is sourced on the CMX. Used by Hammer Bank Logic, Ribbon Drive,
Shuttle Drive and Paper Feed Drive Logic on CMX.
a) Redownload Flash software.
b) Replace Flash Memory SIMM.
c) Check / Replace Hammer Bank Logic Cable Assy (152421-901).
d) Check / Replace Hammer Bank Power Cable Assy (164805-901
e) Refer to Items #1, 2, 4, and 11 to troubleshoot motors and extension cables.
4 = Hammer Bank Interface
Possible Error Messages = 15V CTL FAIL, HB NOT INSTALLD, TABLE MISMATCH
After image data has been processed by the EC, it is passed through this section as dot data,
hammer fire data and clock data via the Hammer Bank Logic Cable Assy (152421-901).
a) Check / Replace Hammer Bank Logic Cable Assy (152421-901).
b) Check / Replace Hammer Bank Power Cable Assy (164805-901).
c) Replace the Shuttle Frame Assy.
I hope this will solve your issue.
Goodluck
If my solution proves useful please accept it.
Regards
Arjun.
Printronix support.
Posted on Mar 27, 2009
  • Arjun Komath Mar 27, 2009
    As told by you, I searched a lot for the flash software, but unfortunately its not available for download in the internet. So, I suggest you to contact the local Dealer to do the needful.
    Regards
    Arjun.
    Printronix support.
kishor khatri
    Genius:
  • 1,913 Answers
Ok first check device manager in comnputer to which printer connect that there are not any yell ! or ? mark.
let me know
also reset all setigns to fsctory defaults.
Louie Role
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding, error code 15V CTL FAIL* is a controller voltage failure (there are others: 8.5, 23.5, & 48.5). The * at the end of the error code is significant. This indicates that it is an internal error and must be attended to by a field service personnel. One of the supply voltages failed its diagnostics. This could simply be a fuse, a regulator transistor/IC or even a fusible resistor, cold solder
Based on the above, your options then are (if not yet tried):
  • Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required;
  • If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required.
  • call it in for service from an authorized service center (if one is available within your immediate area); or
  • consider a DIY (do-it-yourself).
If you are considering a DIY, then your next best move would to get hold of a service manual which maybe purchased from here. Without one, everything else would be guesswork.
Good luck and thank you for using FixYa.
baljit grewal
  • 76 Answers
Google this:Printronix P5010 Line printer software
e-Guru
  • 3,917 Answers
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
My printer shows 15V CTL FAIL. see manual. so the solution
If the Printronix P5010 line printer displays the 15V CTL FAIL message on the screen, use these steps to resolve the issue.
1. When this error code generates on the printer's screen, it might indicate an issue with Ribbon drive (Right), Ribbon drive (Left), +15V Regulator, and Hammer bank Interface.
2. If the issue is with the ribbon drive (Right) & (Left), then do these steps below.
The resistance on the motor should be checked.
To ensure that there are no opens or shorts present in the printer, check the continuity on the Extension cable.
Search for the binding on the motor.
Also, check for the obstacle in the ribbon path which might cause excessive load.
3. If the problem is occured due to the +15V Regulator, then do these steps.
Redownload Flash software and replace Flash Memory SIMM.
Check or Replace Hammer Bank Logic Cable Assy and Hammer Bank Power Cable Assy.
4. If the issue is with the Hammer Bank Interface, then Check or replace Hammer Bank Logic Cable Assy, Hammer Bank Power Cable Assy, and the Shuttle Frame Assy. Call Our Toll-Free 1-866-293-9220
Sep 27, 2018 | The Office Equipment & Supplies
15v ctl fail assy
Bad main board. Get the number off the board as there are 2 different kinds.
Sep 16, 2013 | Printronix LineJet® P7210 Printer
Problem with Printronix psa3 P7210 Printer 15V CTL fail*
Sounds like your controller board is bad but would need some more information from you. Like controller board part# with version #. email or contact me back. [email protected]
Mar 20, 2013 | Printronix Line Matrix P5005B Printer
15V CTL fail*
+15 Voltage Regulator is sourced on the CMX. Used by Hammer Bank Logic, Ribbon Drive, Shuttle Drive and Paper Feed Drive Logic on CMX.
e) Replace the CMX PCBA
Jun 21, 2010 | Printronix Line Matrix P5005B Printer
P5010 line printer, I want to print in condensed mode
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
Jan 01, 2009 | Printronix P5010 Matrix Printer
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Printronix Line Matrix P5010 Printer Logo
3,465 people viewed this question
Top Printronix Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Harrie
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
