what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
A. Powering-on the scale 1.
Press and hold the POWER button for two seconds. Scale will perform a
self-test by displaying four 8s for three seconds. When "0.00 kg" or "0
lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for
normal operation. B. Normal Weighing 1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces. C. Switching between unit weights 1.
Press and hold the POWER and CHOOSE button simultaneously for three
seconds. Unit will change from weighing pounds and ounces to kilograms
and vice versa. D. Taring Weights 1. Weigh a bag or container till its weight is steadily displayed on the screen. 2.
Press the POWER button once. Scale will zero-out and show "0.00 kg" or
"0 lb 0 oz" and is ready for weighing multiple fish together. E. Holding a weight 1.
With the weight displayed on the screen, press the CHOOSE button. This
will hold the current weight and is indicated by displaying an H to the
left of the screen. To unlock the hold, simply press the POWER button. F. Storing weights into memory 1.
With a weight in the hold mode and an H displayed to the left of the
screen, enter the memory mode by pressing the CHOOSE button. While in
the memory mode, pressing the CHOOSE button will allow you to navigate
through ten stored memories. These are indicated on the left and
numbered 0 through 9. There are also 4 letters that indicate other
options. An A shows the average of all stored weights. An E displays
the total and a C resets the memory. 2.
To store a weight, simply hold down the CHOOSE button for three
seconds. Weights will automatically store into one of the number
registers. To see the numbers with their weights, simply scroll through
the numbers by pressing the CHOOSE button as described above. G. Resetting the memory 1.
With the unit in the C mode, press and hold the CHOOSE button for six
seconds and scale will reset memory and zero out. Press the POWER
button and scale is ready to begin weighing again. H. Powering-off manually 1. Press and hold the POWER button for 6 seconds.
Troubleshooting Conair WW81 Weight Watchers Body Fat/Hydration ...
Solve Your "Conair WW81 Weight Watchers Body Fat/Hydration Scale" Problem Now! ... Tanita Ultimate Scale 2001 - no user manual -how to set. ... www.fixya.com/support/...conair_ww81...body.../solutions
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626. Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
1) press both the "set" and the triangle button 2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and 3) press the "set" button.
