Activating Personal RingYou can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
- Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
- Move the cursor to select ON or OFF.
- Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
- Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
- Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
- When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker VolumeHandset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio ToneIf you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
- While on a call, press [Menu/Select].
- Move the cursor to select AUDIO TONE, and then press [Menu/Select].
- Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook EntriesYou can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
- When the phone is in standby, press the phonebook key.
- Find the entry that you want to delete and press [Menu/Select].
- Select DELETE. DELETE ENTRY? appears in the display.
- Move the cursor to select YES.
- Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
- To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
- Press [Menu/Select] and select DELETE ENTRY.
- When the phone asks you to confirm, select YES.
- To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
Note: When you delete a Caller ID number, you delete it permanently.Deleting a Redial RecordIf you want to delete a phone number from the handset's redial list, follow the steps below:
- When the phone is in standby, press [Redial/Pause].
- Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
- When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
- When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
- When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
- In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
- To reset, press and hold [find hs] on the base for five seconds.
- A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Have problems with 4
out of 10 phones all of the phones are 4412D+
Do you have PRI or regular lines?
Are these pots lines or a PRI? When you have a problem, can you call another extension and have the same problem?
If you have the same thing on extension to extension calls, the problem might lay in the system or the phones. If it is fine, it points towards the lines.
On all phones or just a single specific phone?
Are these all 4412 phones, or IP phones. Let me know the model of the phones.
