Symantec Norton 360 Version 2.0 for PC  Logo
Question about Symantec Norton 360 Version 2.0 for PC
Symantec system framework stops working
When running virus scan the above message. Any ideas what causing this? Do I uninstall then reinstall norton?
Any help greatfully received.
Thanks
Posted by rob_sculthor on
  • Anonymous Mar 19, 2009
    Mine is a little different. My Norton program and bar above the internet options don't appear and when i try to uninstall it to install my new version, it freezes and the very end. What should i do?
Anonymous
  • 527 Answers
Sir,
Try to reinstall them. If error occurs go to control panel. click firewal and go to exception tab add the program symantec antivirus. i think it may be solved, if not let me know
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 17, 2009
Updates fail
Microsoft have a .net removal tool which is sometimes helpful to do before reinstalling framework.if this does not work you need a full uninstaller like revo run it and remove scan registry markers.make sure firewall is off and mse is off before reinstalling fresh framework.
last resort is to reinstall over existing Os ...not fresh install!,, then update framework.this is because Microsoft employ too many cooks and the broth is inedible!
2answers
How can i fix my computer with this error... SymCUW has stopped working
Good day. Symcuw.exe is a SymCUW from Symantec Corporation belonging to Symantec Shared Component. These means you have a symantec antivirus or software installed in your system. You can easily remove it by using Malwarebytes - Anti malware. You can get it on this link:
http://www.filehippo.com/download_malwarebytes_anti_malware/
> You just need to click the download the latest version on the right side
> Then install it on your pc
> Allow it to update first
> Then scan your pc
Hope this information will resolve your issue. Have a great day and thanks for choosing fixya.
Dear sir, when i login my laptop symantec anti virus scan don't scan and shows not responding,,,,please tell me the solution
These types of problems occurs if the Symantec Antivirus is corrupted or missing. The only way to fix the issue is to uninstall and reinstall the program again. But before uninstalling the program you have to make sure that you have your product key and the installer handy for the reinstallation. You need to download the Norton Removal Tool to uninstall the Symantec properly.
Thank you for using Fixya. you hig recommendatino is highly appreciated.
My norton 'all-in-one security' 2009 will not run a quick scan - it appears to be scanning but the message at bottom of screen informing me how many files, etc, have been scanned just stays at zero -...
Windows Vista has a very decent firewall. Better than norton. The only way to contact a virus is by inviting that virus onto your PC. You would do this by downloading an unknown file from an un-reliable source on the internet i.e nasty **** stuff which claims to be free. Norton Internet security is a rip off. Your machine will run better & just as secure without it. The world needs to wake up to the computer virus conspiracy. For personal computers AV software is pointless.
1helpful
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
2answers
How do i get rid of a W32.SillyFDC virus
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
1helpful
3answers
Symantec framework has encountered the problem
hey guys , have yall tried uninstalling and reinstalling?
for uninstalling, use the norton removal tool to securely rid your computer of everything of norton. here is the link for the removal tool.
after using the removal tool,
manually dlete excess temp files
start>run>%temp%> dlete everything here
start>run>temp> dlete evrything here
start>run>prefetch>dlete all
restart computer... then you can now install you norton.
post back what happens...
Symantec won;t complete the scan
unistall Norton and reinstall it or try another Virus protection...I prefer either System suite 7 or avast.
Top Symantec Computers & Internet Experts
David Shaub
Mike
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
