Amana ABB1927DE Bottom Freezer Refrigerator Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bottom freezer on Amana refrigerator is too warm,
Bottom freezer on Amana refrigerator is too warm. Top refrigerator is ok. Frig. is about 6 yr. old....thanks
  • 1 more comment
  • Anonymous Mar 16, 2009
    Yes, micbeth1981, there is a little bit of frost on the back of the freezer, what does this mean?...thanks
  • jens23pennie Mar 17, 2009
    Been temping at around 36 degrees for the past 3 hours that I've checked. Frost building up on items.
  • Hannah Schroeder
    Hannah Schroeder Dec 14, 2017
    It's strange that the bottom freezer is too warm, but the refrigerator on top is okay. Both of mine are several degrees too warm, and I need to be able to keep some desserts for the holidays cool. I think an appliance repair company could fix my problem, and maybe they fix yours too. http://abcapplianceinc.com/services
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Mar 16, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316506
Points
2771
Is there frost building up in the back of the freezer wall?mike
  • gladys natkong
    gladys natkong Apr 29, 2014
    there was frost buildup on the back wall of the freezer
Top portion of frig is warm, bottom area seems cool. Freezer below is cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
1helpful
2answers
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
1helpful
Amana Refrigerator leaking in the inside
defrost drain channel is almost certainly blocked in freezer, to rectify turn of overnight leaving doors open, turn on the next day 12 hours later and it should then work ok.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
