I lost my sony ericsson W580i mobile set.i want to ask if i can retreive my mobile with the help of IMEI NO. or my company can help me out in any way to get it back.kindly reply me.
Some phones have the option to use a location feature. if this was on then you may try and see if your carrier will help you to use this feature to find the phone. no promises though.it may be an emergency only thing.
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
hello friend in your mobile settings goto master reset
it will ask about password if can't change that then
enter 0000 otherwise enter your changed password
and than this problem can't solve please i request
go to nearest sony Ericsson mobile shop for repair
because for your no another solution to repair your phone
1.> Get your cell phones IMEI
number. Press *#06# ( 5 key press) and you should see this number
displayed on your phone. Note down all numbers except the last two. You
will need this when you call your providers customer service to ask for
subsidy unlock code. You can also get IMEI number by removing the
battery cover and battery. You should see the IMEI number written on a
sticker. This number is the correct IMEI number and should match the
one displayed when you pressed *#06# on your phone except for the last
two digit. AGAIN DO NOT GIVE THE LAST TWO DIGIT WHEN ASKING FOR SUBSIDY
UNLOCK CODE.
2.> Call you cell phone customer service and
give this IMEI number. Ask them to give you SUBSIDY UNLOCK code.
Subsidy unlock code is 16 digit long number.
3.> Once you
have unlock code, press <**< ( < is left navigation key) key
combination ( 4 key press). Select Network to unlock network and enter
the subsidy unlock code. Press OK. You will see Network unlocked
message displayed. Inputting incorrect unlock more than 3 times will
permanently lock your phone to your provider. So beware when you enter
the numbers.
You now have a Sony W580i phone that is unlocked and can be used with any GSM based mobile providers.
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :- This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone. They should provide you with instructions on how to enter this code into the phone. Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service. The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.Use Google and search for "Security unlocking code” companies in your area.
If you have your IMEI no give to your network provider or police station they will track your cell phone. If not contact your service provider they will verify your information & will track your phone pls rate me tahnk you
hi first of all u should make a complaint to sony service center that ur mobile has got lost..If u dont find any reply from sony then u should make a complaint in cyber crime.. They will ask u for IMEI no. and u should provide them... But mostly u cant get that mobile but u can lock that mobile phone so that the device cannot be used by anyone..
The have the ability to do it, but the carrier will not track the mobile without a court order. Only thing you can do is remove it from your account so that the person who has it cannot use it on your account.
