Question about LG Refrigerators
LG refrigerator model lfx25950tt ice maker not working
LG Frig Model LFX25950TT Ice maker is not working. We do not have an error code. I am turning off the ice maker in hopes of that resetting the ice maker so it will fill with water in the ice maker. Any other ideas I can try myself?
I can not find my manual...that always helps.
Posted by patricia2568 on
mike
    New Friend:
What filter did you replace?
Posted on Nov 05, 2014
Anonymous
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
Problem with LG LFX25950TT Refrigerator (Freezer portion)
It is likely to be either the circulation fan in the freezer or the defrost element. Check the fan is running( you can usually hear it stopping as you open the door, some still run) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer.
Jul 08, 2013 | LG LFX25950 Stainless Steel (247 cu ft)...
LG LFX25950TT error code "ER IF"
This is a faulty evap or ice fan in the system the fan needs to be replaced.
Dec 12, 2010 | LG Refrigerators
How do I turn off the ice maker or the water to the ice maker on an LG LSC27950SW refrigerator?
to turn of water / use the valve behind the frig . or use chld lock on the panel . the ice maker if newer has a off sw . but most just lift the arm on the side of ice maker and leave in the up position and it is off.. mm
Aug 11, 2010 | LG LSC27950 Side by Side Refrigerator
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
My LG refrigerator model#26945TT does not make ice anymore. Any thoughts what could be issue?
Check the following
  • timer, which is located at the rear side of the refrigerator
  • open the freezer casing and check the thermostat
Aug 07, 2009 | U-Line Refrigerator Ice Maker
Our side by side whrilpool frig. ice maker quit working,
I HAVE THIS SAME PROBLEM,I ALSO HAVE THE SAME MODEL.\
I CAN GET WATER BUT NO ICE IT IT SOUNDS LIKE ITS TRYING TO WORK,
BUT NOTHING COMES OUT.PLEASE HELP
NNANCY GREEN
Apr 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
3,483 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
