Nokia 6315i Cellular Phone Logo
Posted on Mar 16, 2009
Nokia phone can't find bluetooth
My old Nokia 6315i cannot find my new H700 bluetooth. The bluetooth works and my phone is bluetooth compatible. My phone found my last bluetooth, but not this one.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
526
Points
9
He you tried rebooting. Completly shutting off the phone and restarting it?
2answers
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
1helpful
2answers
I was paired to one phone, now I need to "unpair" because that's what Verizon told me to do, the phone pairs, but won't connect.
No such thing as unpairing, remember that not all bluetooth devices are compatible. A complete list of phones that are compatible are located on motorola's website, under consumer products, bluetooth. BTW, if you don't know the pin to pair the devices is 0000
6helpful
2answers
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
It wont work on my sliver
Compatible with Bluetooth v.1.2 enabled phones from Motorola and other manufacturers. Backwards compatible with v1.1 devices.
It wont connect to phones
2answers
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
3answers
Palm Centro and Moto h700 bluetooth
I think its a compatability problem also. you may have to get a headset specifically designed for Centro or try a plantronics headset they work great www.n1wireless.com
28helpful
4answers
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
