When i press the power button there is no picture but the green light comes as if the tv is on after a few seconds it turns off and the red light comes on
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
