First off is the water filter bad and or do you have one...if not and it is good...then you have pretty much diagnosed the problem correctly...as you said the old Ice maker gears turn and when they make a complete revolution they engage a trigger which signals the water solenoid to dispense water to the ice maker...another test is to fill the ice maker manually and see if it freezes (test the temp of the freezer...if it is not cold enough the ice maker will not work)...if ice is made (generally under 4 hours ) and it is not dumped...you need to replace the Ice maker...around $30 to $50depnding on brand and where you buy it...I shop Marcones Appliance parts the appliance repairman's friend...good quality cheap prices.
Good Luck I hope this helped...please rate me ...the Fang.
The ice
maker not working: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
