Question about Microwave Ovens
Magic Chef won't work - clock works
I have a 1.8 cu. ft. Magic Chef microwave oven. Friday night I wasreheating some frozen chili - about 20 minutes. The microwave juststopped when I tried to resent it for 10 more minutes. The clock worksand it counts down. It just won't come on. There is a little clickwhen you press the start/stop. Does anyone know what's wrong?
Posted by Peach1952 on
  • Peach1952 Mar 16, 2009
    The fan is not working. Do you know what I need to do to have it fixed or would it be worth fixing? The microwave is not a cheap microwave.
John Broderick
  • 82 Answers
Does the fan run?
If not, it's a control board fault.
If it does run, it's probably a high voltage problem.
Posted on Mar 16, 2009
  • John Broderick Mar 16, 2009
    If the clock counts down but no fan etc, sounds like a serious fault on the main control board; they are usually not worth repairing.
    Usually the whole machine has a fuse internally and then just the 'high voltage', there isn't one for a fan.
    A fan not running could be difficult to fix unless you know someone into electronics.
    The fan is switched by the same control that switches on the component that heats the food (The Magnetron)
    You're unlikely to get it fixed unless you find another machine on eBay with a different fault.
    (rob the good bits)
    Sorry.
    Thanks
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
Why is my MCO165UB display not illuminated?
Is the unit plugged in and is the light on inside when you open the door? If so you could have a blown fuse. The cabinet must be removed before you can replace the 20 amp fuse. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | Magic Chef Over the Range Microwave. 1.6...
Where is the fuse for a 1964 FORD Fairlane?
I did not know Magic Chef made the Ford Fairlane!! Please post on the automotive area. It has fuses under the dash and under the hood.
May 22, 2014 | Magic Chef 1.6 cu. ft. Over-the-Range...
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
Where is the fuse
where is the fuse for my heater as its not working on my renult modus
Jan 03, 2014 | Magic Chef 1.6 cu. ft. Over-the-Range...
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Oct 02, 2007 | Microwave Ovens
Microwave Ovens Logo
146 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
