HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have document created on Microsft Works Database, in Lanscape mode. Printer will not print in landscape. Message that printer is out of memory. documets were created when I had older lexmark printer, and I had no problem printing them until I purchased your printer in 12/08
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Mar 16, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
6
Helped
18838
Points
133
Try re-saving doc in microsoft word format and or adobe format then print see if that works.
How so I do Landscape orientation on Canon Pixma MP500?
When you want to print a document Click on File (at top left hand corner of screen) - click on Print then click on Properties box - Layout tab then select Landscape.
The printer normally defaults to Portrait but sometimes you want to print Landscape. Use this method when you need to print in landscape mode.
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
1helpful
3answers
Print jobs print as portrait and not landscape
you need to change the print settings in the program where you are printing, when you go to print settings the option should be in the dialog box where you choose the printer and page amount.
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Hp 5650 will not respond to LANDSCAPE PCL command ESC "&l10" This works on other HP priners Can anyone help? Morris Bishop on [email protected]
open printer and faxes go to printing preference then click printing shortcut there you can see orintation select lanscape apply ok it will work ,Also select page size A4
2answers
Microsoft Word problem
This error message may occur when there is a wrong Printer selected when u try to Print but if it still says the same thing just uninstall and reinstall Works and Check............
Good Luck
2helpful
2answers
HP 1280 Error message
well...the printer settings will be the key. open them up and make certain that you're tray assignments are in line with your A4 paper.
Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
Printing
Some net printouts need to be printed in Lanscape mode. For example I just selected Print Preview on this page and some of the right side is missing. You can use page setup to select landscape.
Hope that helps...
Geno
1helpful
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
k24674
Grand Canyon Tech
Grand Canyon Tech
