Question about JVC GZ-MG130U Camcorder
"please insert memory card in GZ-MG130U CAMACORDER
When i try to recording in my hard drivr camacorder screen disply "please insert memory card" & i cann't recording.if i insert SD CARD THEN IT WORK.this is a 30gb hard drive camera it don't need to sd card.sd card need only on photo mode.please give me suggestion
Posted by yogeshradadi on
Lee Hodgson
  • 4,810 Answers
Hi there.
The hard drive will be full so you will need to transfer all your videos to your PC then format the hard drive in the camera's menu, make sure the SD card is removed before you format it.
Good luck and thanks for using FixYa!!
Posted on Mar 16, 2009
tbalon
    Problem Solver:
  • 5 Answers
You need to tell it in the settings menu that you want to record to the hard drive instead of the SD card.
Posted on Oct 15, 2009
4 SDHC 8GB Card Error that"this card cannot be used to record or edit" What can I do? Thanks!
The message is clear. You cannot use the card.
You can check the manufacturer's website to see if there a new firmware. If there, is update the firmware (anyway) and hope it will support the card format. If there is no new firmware, read the manual for the type of cards and capacities supported and buy compatible cards. The old card can be returned to the store, sold to someone, or saved for future devices.
Jan 11, 2014 | JVC GZ-MG130U Camcorder
What does it mean when I get a message that says "please insert memory card" on my JVC Everio GZ-MG21U?
Make sure you're using an SD card, not a higher-capacity SDHC card. The GZ-MG21U works with SD cards, not with SDHC cards.
Sep 24, 2012 | JVC Everio GZ-MG21 Camcorder
Do i need a memory card to record..
No you do not need a memory card to record. The JVC Everio GZ-MG130 is a hard disk drive camcorder with a built-in 30 gigabyte hard drive to record to. You can, however, use an SD memory card if you want to add additional space to save your videos and pictures to.
Jul 07, 2011 | JVC Everio GZ-MG130 Camcorder
What do i need to watch video for mac computer for a jvc everio gz-mg130u? I tried everything to get to watch the video. This for a mac book
try to connect the cable of your cam through the USB type ...insert in to PC... then, data storage must be select to open the file in your computer..
Oct 19, 2009 | JVC Everio GZ-MG130 Camcorder
I have a JVC gz-mg130u HD camcorder that willnot work in Vista
The short answer is that unless JVC have released a firmware upgrade to this model, currently its not support for use on vista.
You can try here though, for some upgrade info,
http://support.jvc.com/consumer/support/index.jsp
Thanks
Nov 28, 2008 | JVC Everio 25x/20GB Hard Disk Drive...
HDD Error!
Take it to a camera store or to a Best Buy store and see if the hard drive has a problem with it such as a bent recording head.
Did the hard drive format completely?
Nov 26, 2008 | Video Cameras
Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Nov 23, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
GZ-MG130U
replace the fpc wire which is coming from lcd disply unit to mainboard
Dec 26, 2007 | JVC 580136 Camcorder
JVC GZ-MG130U Camcorder Logo
641 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
