Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite side by side has water that pools in the freezer.
Model # 795.75193401. THe water seems to pool from the back vents of the freezer. the water pools at the bottom of the freezer, refreezes and somehow drips out of the freezer onto the floor as water.
Posted by rodneyamiles on
  • Anonymous Mar 26, 2009
    Anyone know how to fix the ice that builds up in the bottom? Water builds up quickly and freeze in the bottom. Also water runs out the front. Anybody have the sulution? This is getting really old.
    Thanks in advance
Anonymous
    Genius:
  • 1,122 Answers
You need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Posted on Mar 16, 2009
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore model 253.7419240p water pooling under crisper
Do you see any ice buildup on or behind the back freezer wall?
Oct 31, 2012 | Kenmore Refrigerators
What is wrong with Kenmore Elite 795.75192400?
dear Bill if its a no frost refigerator sounds like you might have to take all the drwars out unscrew or detach the back plate and defrost the fridge manually and then unblock the drain hole which goes to the back of the fridge into a plastick container ontop of the compressor which in turn will evaporate from the heat of the compressor . Hope this does the trick .. good luck. Tony
Dec 01, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
Water pooling under freezer side of cabinet. Ice forming in bottom of freezer.
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed back..mm
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
384 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
