Question about Mitsubishi Televison & Video
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
Posted by Kellie Murray on
Anonymous
    New Friend:
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Posted on Jun 02, 2010
How to operate with remote control
VCR Remote Control Buying Guide ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
REMOTE CONTROL MANUAL Synergy V - RCN
help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC.../index.htm
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
www.cox.com/business/support/.../article.cox?...
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Jan 14, 2016 | Televison & Video
Net command mode need to be set
I have set the remote rm 75502, but it is not recording
Mar 02, 2013 | Mitsubishi RM75502 TV/VCR Remote Control
Looking to obtain a HS-U448 manual and remote.
The manual is available from the Mitsubishi Support site: http://support.mitsubishi-tv.com/documents/HS-U448 . The direct link to the manual is http://support.mitsubishi-tv.com/files/oguide/HS-U448.pdf .
The original remote is no longer available. However, remotes.com has a substitute remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HS-U448&uuid=13065385902780 .
A number of universal remotes will probably also work. The codes will be in any remote that still controls a VCR if the remote was programmed after the HS-U448 was released.
I hope this helps.
May 27, 2011 | Mitsubishi HS-U448 VCR
I have no remote for the tv Sylvania 6313ce 13" TV/VCR. I am trying to program a rca remote for it so I can change the channel to 3 so the converter box will work, how do I do that
This particular TV may have the same code as a Magnavox,Emerson, Funai ,or Zenith. You will have to look in the remote control manual for these codes. This TV was put together by other manufacturers. And in many cases they program these to their origin! Thanks for asking and show a few hands of support!
Jan 11, 2011 | Sylvania 6313CE 13 in. TV/VCR Combo
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Lost manual
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Sorry the manual was not the correct one for this remote. I thought it would provide simular codes to your product.
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Sep 12, 2008 | Jensen 143307 Remote Control
Mitsubishi tv model no. CS-2567R
I had no luck finding anything for this model number even on the Mitsubishi site. How old is this set?
I would try programming the remote to some alternate codes for Mitsubishi products. It sounds like it's not programmed correctly. If you don't have the codes I would search the web for your brand of universal remote to see if you can find it's instructions. Lastly, on the topic of the remote, most universal remotes have a method to program even when you don't know the codes. This usually involves turning on the TV then putting the remote into a specific mode and hitting the power button until the TV shuts off.
How are you connecting the dvd/vcr? Are you using a single coaxial cable (the kind with the threaded connector) or are you using composite cables (yellow, red, and white plugs) or some other type of cable? If you're using the coaxial cable then you will typically find the signal on channel 3 or 4 on the TV when the source is set to tuner. If you're using one of the other methods then you will need to find a button on the set labled something like "Video Source" or "TV/Video". If you hit that button the TV will switch through it's input sources. It's very possible that this feature will not be available on your Universal remote even if it's programmed properly. You may have to select the source on the TV itself.
Good luck and let me know if any of this helps.
Nov 27, 2007 | Televison & Video
Lost tv code
Here are some of the codes2.gif still looking for manual
Mitsubishi TV4.gif 0093, 0150, 0178, 0019
JVC2.gif VCR 0067, 0041, 0008
JVC DVD1.gif 0558, 0623
samsung1.gif codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola2.gif Cable2.gif Box: 5000, 5003, 5046, 5047, 5052
Comment by Gigatech, posted on Dec 10, 2007 Here is some helpful information4.gif I found:
2. Press the device4.gif button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
Jan 03, 2007 | Jensen 143307 Remote Control
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
