Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
My freezer stopped working and has thawed everything out (I lost everything). The refrigerator is working fine. The freezer is blowing cool air but not freezing. Any thoughts?
Posted by tom2858 on
  • Havingfun1 Mar 18, 2009
    I have a KitchenAid Superba Side-by-side KSCS25INSS00, 3 years old. The centeral wall in the front at the door seals was getting very hot. I read on a blog to clean the coils to solve this problem, so I did, but only in the front below the doors. It did not help much if at all, and then the freezer started to thaw and the ice melted and pooled on the floor. I read more and took the inside of the freezer apart and saw the coils in there were not frosted over and then pulled the unit out from the wall and opened up the lower back panel. I found lots of dust and cleaned it of the coils in the back of the unit. I plugged the unit back in and by the next morning and the centeral wall was much cooler, and the freezer was doun to 0 degrees. Two or three days later the new ice was melting onto the floor again and the freezer is now staying at 38 degrees F, it is set for 0 degrees F. The freezer seems to be staying about 1 degree F cooler than the referigerator side. Any suggestions on what to do next.
  • Anonymous Mar 17, 2014
    The refridgerator side stopped working but the freezer side works fine. What could it be?
Anonymous
  • 170 Answers
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls everything...one sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
Posted on Mar 27, 2009
My freeser is working other side is not cooling the top vent getting air but not underneath
You need to thaw the ice which has clogged the passageway from the freezer to the refrigerator. To do this, you can turn off the whole unit for several hours and let everything thaw, or you can remove the panels and locate the vent(s). Melt the ice with a hair dryer, then reassemble the panels and restart the refrigerator. There is a small chance that the fan in the freezer has frozen up as well. When the refrigerator compressor runs, you should also hear a small fan in the freezer run. If not, you will need to do some investigating to find out why.
Apr 25, 2012 | KitchenAid Refrigerators
FRIDGE AND FREEZER QUIT COOLING
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Frig working, freezer stops working, then starts working again
The computer control circuit board was found to have a burned out circuit. The board is on the lower back side behind a panel, easy to replace. Just need the proper model number to order the board.
Sep 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Freezer is only cool, everything melting
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
630 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
