GPS Logo
Posted on Mar 15, 2009
Magellan GPS Pioneer will not hold onto satellite signal
I have a Magellan GPS Pioneer and it has not been used for approx one and a half years. the problem i am having is that the unit will not hold onto satellites, it picks them up but looses them soon after. i have reset the unit but it's still not working.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4406
Points
24
I had the same problem. Found this link
http://forums.groundspeak.com/GC/index.php?showtopic=144134
As suggested at the end of the above thread I left my unit outside for a couple of hours and it suddenly sprang into life. Now it reliably gets a fix in 2 to 3 minutes when I switch it on.
My theory is that because it is only a 2 channel unit it takes hours to acquire a fix when the memory is blank.
The manual says it will keep it's memory for a month without batteries.
So if you leave the batteries out for more than a month, or move it more than 250 miles and then switch it on expect it to take a while to first fix.
Otherwise it's a nice little unit.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4158
Points
7
I had the same problem with my Magellan Pioneer GPS - it would not hold satellites. So I left it on a plastic table with the antenna pointing up and a clear view of the sky for 1 hour and it acquired a fix.
Bill Lionheart
Level 1:
  • Posted on Jun 18, 2021
Bill Lionheart
Contributor
Level 1:
Answers
Questions
0
Helped
4158
Points
Try setting the date to 1024 weeks in the past. The GPS 10 bit rollover bug means means it reuses dates every 19.6 approx years. So if you enter the correct date in the quick start menu it is looking for the wrong sats.
No signal
Your GPS is defective. Contact Magellan for repair return instructions.
4helpful
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
7helpful
Magellan Roadmate 2036-mu will not find satellite signal at all. It straight out of the box. tried having it in clear view of the sky, and still nothing. Any suggestions?
Slide the power switch to turn it OFF and hold it in that position for about 20 secs or more. Release the switch and now restart the GPS by sliding the power switch again. The GPS should start up and start searching for satellites.
2helpful
With the GPS turned ON; slide the power switch to turn it OFF and continue to hold it for another 20+ secs. Release the switch and restart the GPS. It should try to locate the satellites, if it still is not able to find after reset then this could be a hardware problem with the GPS.
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
2answers
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
2helpful
2answers
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
Magellan 760 does not find satellites
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Magellan 310 Signal Won't Lock In
Turn on the power while holding down the right arrow. This will reset the unit. You will have to reset the location, date, and time.
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
