Headlights, running lights, windshield wipers not working. already replaced inline fuses off from battery
SOURCE: headlights 1991 nissan pathfinder
hammerhamcd
Your year Pathfinder, as mine, had a slew of bad head light switches. The headlight switches caused a slurry of intermediate nightmares for a lot of customers. Many complaints included:
1. My head lights sometimes turn off upon switching from low to high beams.
2. My lights turn completely off when I switch to high beams.
3. My lights flicker when I switch from high to low beams and vise verse.
4. My lights sometime wont turn on at all.
5. My lights go on and off on bumpy roads.
6. My lights sometimes come on by themselves.
All of these different but similar complaints contribute to the infamous head light switch. There has even been reports of continuous dead battery's due to the head light switch turning the lights on and off intermittently and eventually deadening the battery.
The light switch is relatively easy to replace. Simply remove the the two upper and lower steering column covers, disconnect the two wiring harness bulk head connectors, a couple screws and wallah.
Remember your safety and always dissconncet your your battey upon electrical repairs.
Just last week I bought a new head light switch for about $70.00. I would highly recommend buying a new head headlight switch and not buying a junkyard special. You will likely be buying another faulty switch.
Good luck!!!!
Triple H Outfitters
SOURCE: 95 pathfinder only 1 headlight comes on both bulbs good
im a mechanic who owns a1995 pathfinder, had the same problem.your trouble is in your daytime running light module. try giving it a tap, bet they will come back on
SOURCE: 1986 300zx headlight problems
If I remember correctly nissan uses a L&R high and low beam fuses,might want to double check them,but if you need any diagrams just ask have a good day DB
SOURCE: headlight assembly switch does not work properly
I would say try replacing headlight switch...I have the same problem and will be doing that tomorrow
Fuses are located either in the engine compartment or passenger compartment fuse and relay panels. If a fuse blows, a single component or single circuit will not function properly.
