My washer will fill and agitate, but it doesn't drain and rinse. Then if you put it to spin cycle it will spin but not drain. The problem began by getting stuck and not doing anything prior to rinse except make a funny noise.
I had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Is it a front loader?
nope.
i have the same problem. as we speak my washer is sitting there full of dirty water and wet clothes. it will agitate but not drain or spin. :( What to do, what to do...
The plate for the switch is broken so when you close the lid, the plate that activates the switch is not there. I reached under neath and found what was left of the switch plate and was able to push it down with my finger; put it to spin and it started spinning. Now all I have to do is go to Reds TV and Appliance and get a new switch (and figure how to get the top off of the washing machine !!)
