Have lost some oil out of standing kitchenaid mixer in moving, what oil do you use and where do you put it in at ???
Hi. The oil you see used to be mixed into the grease base. It's time to change the grease in your mixer. Remove the silver band, Remove the top cover. Remove the transmission cover. Clean out the transmission, remove all grease and oil. Replace with Chevron FM ALC EP-2 grease. This grease is an edible food grade..
Remove the planetary gear, clean and re-grease. If this solution has assisted you, please rate it. ricardok45
