Akai LCT2715 27 in. LCD Television Logo
Posted on Mar 15, 2009
Akai troubleshooting Akai LCT2785TA we turned it off and now it won't come back on.
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Mar 17, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
22197
Points
37
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2785TA POWER SUPPLY BOARD MLT186
Thanks
GEORGE
I have an Akai LCT2785TA that won't power up. The switching relay on the power supply board doesn't seem to energize wjen commanded (by either the remote or front panel). Do you think I need a new power...
Yes, look to see if it has any bad caps, check the voltages.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
My akai lct2785ta will not turn on at all.
Unplug it for about an hour to let it reset itself first, if still the same then check the power supply first.
I have a brand new tv and it has never powered on
If the ac cord is fully functional and theres ac voltage supply from the wall outlet the power board needs troubleshooting and servicing, if its under warranty take it back...
3helpful
2answers
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Akai LCT2785TA troubleshooting
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
FixYa database totally screwed up!
Oddly, entering only the model number - LCT2785TA - brought up only pertainent messages although I see it often that some folks manage to enter car problems under washing machines for example so it isn't only the Fixya search facilities that are screwed up, sometimes it is an entry error.
Now, I'll see if I can find your original problem message since you didn't bother to keep it connected to your complaint.
Akai Replacement Parts
If power supply works do you have the number on it there are 2 different ones that work how do I pay you email me [email protected] thanks
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
