I have an exhaust manifold leak that makes a loud ticking noise. It ran terrible and was throwing several codes, mainly the exhaust actuator sylnoid. I replaced that(was all caked with oil and the screens plugged)flushed the engine and replaced it with new oil. Now it runs better, but I still dont have power and have to be in 3rd in order to get to and maintain 55 mph. There is a loud whistling noise that starts under a slight load and gets louder. If I push it, i can get it to have the check engine light come on and have it will miss fire at idle, oil pressure drops off to zero. Throws a code for O2 sensor and miss fire #4. Both O2's are replaced and changed plugs. I read something about using only ac delco plugs? does that make that much difference? Would my exhaust manifold leak throw it off that bad?
SOURCE: Truck has a hesitation just off idle and service
Map sensor is usually on the firewall and has both an electrical connection and a vacuum hose going to it. Mass air flow is in the air duct from the air cleaner to the throttle body. Two small wires are stretched across it's bore. clean them with a Q-tip and carb cleaner.
SOURCE: 2001 S-10 with 4.3 misfire
Check for vacum leaks make sure hoses arn't cracked and are routed correctly. check for leaks at throtle body, intake manifold, egr valve and pcv system. also check to make sure pcm is grounded correctly. Check injecter harness connectors aswell.... Hope this helps if all this looks good... you may have to take it to a shop where they can make sure the injecters are firing and compresion is correct.
Good luck :)
SOURCE: 2001 Silverado 5.3 1500 extended
P0300 is caused by all the cylinders having a random misfire, this is the rough idle u have, i suggest u have the fuel injectors professionally cleaned (not the snake oil u pour in the tank, that doesn't work) with the GM high pressure injector cleaning machine, and also have a cylinder power balance test run, u may have worn valve guides or a worn camshaft. Be prepared for the fact u may have a worn engine problem
