I just got a Plaintronics M25 and it will not pair with anything. I followed the instructions and waited for the red and white flashing light... Both my IPhone 4 and my Garmin nuvi will not recognize that a bluetooth device is trying to pair. Yes i have set both devices to bluetooth on and pairing/search/discover mode. PLEASE help!
SOURCE: Plantronics Explorer 220 bluetooth won't pair with
Well I got it working, of course, try turning the phone off on again instead of just the bluetooth, it worked. I should have done that before posting the question.
SOURCE: Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
SOURCE: PAIRING PLANTRONICS BLUETOOTH WITH IPHONE 3G
On your phone. goto the Bluetooth menu and select "Add Device or Add Headset"
Refer here to put the headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator
begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
