Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Posted on Apr 24, 2009
Call for warranty service. If it is running and not cooling, there may be a refrigerant leak. (You may even be able to see signs of this yourself if you take the cover off the compressor area in back and look to see if there is any sign of oil. If there is any oil, there is a refrigerant leak) If so, push to get refrig replaced, as if the unit ran for several days and thus sucked moisture into the normally sealed system it may be repairable, but is a major repair and may shorten the life expectancy of your refrig. (I hope you did not purchase from Sears, as they buy from GE without the GE factory warranty, and thus you would have to deal with Sears for any help. Good luck.)
Posted on Mar 15, 2009
May 06, 2015 | Refrigerators
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jun 09, 2011 | GE Profile Stainless Bottom-Freezer...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 18, 2011 | Pds GE Profile¿ Energy Star®...
heatman101
Apr 15, 2011 | Maytag 25.6 cu. ft. Side-By-Side...
Mar 31, 2011 | GE Profile Bottom-Freezer Refrigerator...
heatman101
Nov 21, 2010 | GE Profile Stainless Bottom-Freezer...
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
Oct 05, 2009 | GE Refrigerators
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
772 people viewed this question
