Directv HR10-250 DTV Receiver Logo
Posted on Mar 15, 2009
How do I enable the stb services port and audio services port on my DIRECTV HDTV Receiver?
How to balance audio levels with Yamaha RX-V485 receiver, Cable STB and TV audio
I HAD VERY SIMILAR PROBLEMS WITH PIONEER VSX 523 UNTIL GOT MEDIA BOX FOR TV SO ALL INPUT/OUTPUT ON AMP WERE HDMI AND NOW SOUNDS AND WORKS BRILLIANTLY
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-rayâ„¢ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
HELLO MY NAME IS ROBERT. I HAVE A QUESTION. I HAVE A YAMAHA RX-V363. I ALSO HAVE A PANASONIC ST30 PLASMA 3D. AS WELL AS A PANASONIC BLU-RAY. AND DIRECTV HD BOX. HOW WOULD I EVEN START TO CONNECT THE HDMI...
The TV may have HDMI ports, but the V363 may only have RCA outputs.
Video Audio HDMI Male to 3 RCA AV Cable Adapter Audio Video Component DV Convert HDMI to 3-RCA TV Adaptor Line For HDTV 1080P AU https://www.aliexpress.com
Try here.
2helpful
I have purchase an onkyo HT-RC230 receiver. I want to connect a Directv R16-500 DVR & RCA L32W22 TV. Directv satelite service is currently connected to the DVR and DVR is connected composit S ports of ...
This is a rather uncomplicated satellite receiver, and basically only has a left/right audio out.
You can hook these into any of the stereo type inputs on the HT-RC230.
This receiver is also the "wal-mart" brand of Onkyo (not their best stuff) - so I suggest you take the L/R audio out on the DVR and put it into ANY available (cd/tape/dvd) stereo input on the receiver.
You aren't going to get better sound out of any specific input.
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
5answers
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Can't see or listen to stb when changing input source and go back
Maybe the STB detects that there is nothing "listening" on the other end of HDMI and turns its output off. Does it work again if you turn off+on the STB without touching receiver?
2helpful
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
