Question about Canon i9900 InkJet Photo Printer
Canon i9900, orange light blinks 5 times, won't print. I Cleaned the print head with denatured alcohol and it still wouldn't print. As soon as the print head gets all the way over to the right, the orange light starts to blink.
Posted by nfgriffin on
  • Anonymous Apr 01, 2009
    same problem. didn't try cleaning head, but i've turned off/on, unplugged unit, and cleared print queue.
Anonymous
    New Friend:
    Problem Solver:
Clean the printheads and the ceramic part_ still blinks 5 times orange and not printing. can anyone help me
Posted on Jan 26, 2011
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
Printer does not print. yellow light blinks 5 times
Printer does not print. yellow light blinks 5 Problem with the Canon i9900 InkJet Photo Printer
Aug 03, 2010 | Canon i9900 InkJet Photo Printer
I have the Canon i9900 printer. I am having a big (big to me) problem with all of my prints coming out with a brownish cast. I am using Photoshop Elements 7.0 for imaging and have Photoshop CS4 (Don't use...
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Feb 08, 2010 | Canon i9900 InkJet Photo Printer
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i9900, orange light blinks 5 time upon start and continues to blink the same
This error mean "the print head is failed".You need to replace the print head.It's part number is QY6-0055.
Nov 19, 2009 | Canon i9900 InkJet Photo Printer
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
Pixma i9900 orange light flashes 5 times
hi guys,
Flash in orange 5 times indicates that the printhead is faulty so that the printer cannot detect the printhead. Rarely, faulty logic board and carriage unit may cause the same problem.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon i9900 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
old marine
old marine
efs_perpends
efs_perpends
