My BlackBerry Bold 9900 keeps popping up a messge "your device is currently in Safe Mode...to remain in Safe Mode, click OK. To exit Safe Mode, click Reset". However clikcing Reset just takes you in an endless loop to this message. In addition, the back/esacpe key will not work. I've tried pulling the battery and downloaded the latest OS to no avail. Any suggestions?
SOURCE: memory card error message on blackberry bold
hi there!
regarding your problem, i think you must try to reformat your card using your new phone (blackberry bold 9000) for you to be able to use that card in the said phone.
just let me know if you need more further assistance.
nice day.
SOURCE: jum error 102 on blackberry bold
https://www.blackberry.com/Downloads/contactFormPreload.do?code=1141938BA2C2B13F5505D7C424EBAE5F&dl=20E9452CEC42D5E5133B1895B4AE7906
Requires you to fill out registration fields, but it's free and it should help you resolve your issue.
SOURCE: my device shows app error
CHECK YOUR USB CONECTOR OF PHONE MAYBE IF DAMAGE
CHANGE YOUR USB CBLE
CHANGE USB PORT OF YOUR COMPUTER
SOURCE: Blackberry Bold running latest software,
Well you can again upgrade the 9700 software from here
http://senseapplied.com/index.php/upgrading-blackberry-9700-and-9300-to-firmware-6-0-0-448/
If you like the solution do give us all thumbs up
Farhan
SOURCE: how do i restore my blackberry bold 9900 to
Good Day, Goto Options, then to Security, and click Security Wipe. You can enable the first two boxes. But note that everything on your phone will be wiped off except if you backup your data. Mind you, your applications can't be backedup.(You can backup User data by using BB Protect or BB Desktop Manager) By doing the above, you have done factory restore. Try this and be kind enough to rate my solution. Thanks for using Fixya!
