If your computer recognizes your phone when you plug it in, you may have a problem with the lcd screen.
When my Sony W810i had the white screen problem, I was about to buy a new phone when I found out about the Sony Ericsson Update Service (SEUS). I
used it to fix the firmware inside my phone, even though the phone
seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w810i?lc=en&cc=us
If you are seeing a white screen 1 of 2 things has happened. The connector for the LCD may have come loose or the LCD itself has gone bad.
Checking out and replacing the LCD screen on the Sony W810i is a pretty straight forward procedure.
I would take the phone apart and check the lcd connector first. Reseat it and try it out. If it is still white, your next step is to replace the LCD screen. This should then take care of the problem. A new LCD screen runs about 30 dollars from Ebay.
Take a look at the following link to see instructions and links to buy the lcd screen
Sony Ericsson W810 LCD Display Screen Replacement
I hope that helps out
When does it show white screen ?
