Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher and paykel DD605SS
The top dishwasher doesn't work and when we turn turn the dishwasher on ti makes the beeping sounds but somehow the bottom dishwasher works fine. when we turn the top one on then after about a minute it stops and starts to make the noise again and it continuous shows the lock. any help would be greatly appreciated The same thing happened with my Fisher and Paykel DD603 dishdrawer, however because I am in a small flat I only have the one drawer.
I have tried reseting it by holding down the three buttons, but it didn't help.
Occassionally the cycle will start after doing this - but will stop quarter or halfway through, the lights flashing and constant beeping.
Posted by mel_o_drama on
Anonymous
  • 144 Answers
I can talk you through finding the fault on live chat. cheers
Posted on Mar 27, 2009
4 Related Answers
Anonymous
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
Anonymous
  • 145 Answers
SOURCE: current service manual for the Fisher & Paykel DD603SS dishdrawer
I realize this is an older post but for information's sake in case someone happens across this subject, you can get the manual for a DD603 series dishdrawer here:
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18
Posted on Dec 15, 2008
Anonymous
SOURCE: possible pump blocked
dishes have white film glasses are foggy
Posted on Feb 11, 2009
Sam
  • 3247 Answers
SOURCE: My Fisher & Paykel dishdrawer dd603 is
the flood switch at the base of the dishwasher has been activated. This means moisture has gone into the base (under the drawer).
Turn power off, and extend drawer to expose bottom back of the base. Use towels / hair dryer etc to dry it out.
Likely causes are - you used a wrong detergent (too much foam) or the hoses at the back are leaking or the actuator arm that supports the hoses when you pull or push the drawer is broken and the hose is kinked.
Hope you can fix it.
Posted on Dec 12, 2009
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
No power top drawer
Try to reset your dish washer. Turn off main power supply and leave it for at least 1 min. Is there any error code appear/beeping sound?
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
1helpful
Drawer wont drain and motor noisey
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
2helpful
3answers
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
1helpful
hold all three bottons: power, pause and start and power cycle the unit, it will reset the dish washer.
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
