How do I turn this off?
It say that the windows need to be activated but when say ok it already activated
Windows XP fix: go to CONTROL PANEL... double click on POWER OPTIONS and set the option "Turn off monitor" to NEVER if you want it to stay on.
Hi! Normally monitors don't enter power saver mode if the user is continuously moving the mouse... or, the monitor itself has this "power saving" feature. Try entering the On Screen Display by pressing Menu on the monitor. Navigate to the part that says "power saver" and disable it. If you can't find any, then i suggest that you try a different monitor. If the problem persists, then there must be something wrong with the monitor forcefully entering power saving mode.
Let me know if this helps. I'll be glad to provide more options.
SOURCE: Dell 17" flat screen monitor
When they stay in power save mode the logic board is usally the problem. Cneck out www.lcdrepair.us they sell all the parts for that unit.
SOURCE: when i turn the computer on the monitor says it is
Sounds like your monitor is not getting any signal. The monitor is probably working fine its the video card or connection that is having the problem. Check all cables, then check to make sure video card is working. Does your computer POST without any problems when you turn it on? Do you have an onboard video port and a AGP/PCI-e/PCI video port? If so, is your video connected to the onboard or the AGP/PCI-e/PCI
SOURCE: my monitor is stuck in power saver mode
There is something electrically wrong in your monitor which an electrician can identify and fix. There is nothing to worry, some capacitor might've shorted out. It'll be fixed cheaply. Hope this works.
SOURCE: LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Testimonial: "Settings are not the problem. The problem is with monitor itself and it is not related to operating system."
OK - that sounds great, but how do I get to the control panel when the monitor keeps shutting off right away after it says Power Saver Mode? Let me know if you can help.....thanks.
Well, guess what --- just checked the connections and found out that my son plugged the monitor into the wrong spot.....thanks for your help though.
My Dell keeps saying "Entering Power Save Mode. I can't get it to wake up. Please help.
