Question about Toshiba 32AF41 32" TV
After lightning, my television did not work
After lightning, my TOSHIBA 32AF45 television does not work anymore. No sound, pictures and power light. How can I fix it? What would be problem? How can i find spare part of it? Thank you.
Posted by necmid on
Ginko
  • Toshiba Master
  • 19,396 Answers
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here.
Posted on Mar 15, 2009
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,001 Answers
Lightning Cable , USB Charger Cable for Apple, Lightning Cable for Apple,Cable Cords Connector with Nylon Braided Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
Posted on Dec 30, 2016
Thunder cut my power off came back on but no picture or sound red light just on please help
Hello
Power supply board has damaged. it must be checked well for faulty components. We cannot predict the fault due to lightning. It will be best to replace the power regulator board rather than making surgery with it now in this condition.. OK.
May 03, 2011 | Toshiba 36HFX71 36" TV
I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Jun 20, 2009 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
TV turn off by itself
The easiest way to describe this is to measure the center pin to either outer pin. If either combination reads shorted, that is the problem.
Dan
Sep 03, 2008 | Toshiba 32AF45 32" TV
Missing channels
Try going through the auto program feature first and see what happens. Otherwise if the set is new have it replaced.
Apr 12, 2007 | Toshiba 32AF45 32" TV
TV Problem After Lightning Strike
check the diodes or the regulator. the diode are most likly shorted that the 4 d's like d800, d801,d802,d803
Dec 26, 2006 | Toshiba 32AF45 32" TV
Will not turn on
The power surges and lighting damages are ussually extensive,alot of times more than one component and more than one circuit gets damage,home owner insurance cover this damages but the insurance company does not repair the damaged unit they replace them because is not worth repairing.To troubleshoot you will need the squematic diagram to locate and correct the different circuits that might be involved ,be careful there are voltages that can hurt you if you are not too familiar and touch one by accident.
Nov 04, 2006 | Toshiba 32AF45 32" TV
Toshiba 32AF41 32" TV Logo
1,405 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
