Question about Nokia N500 Auto Navigation
Nokia 500 GPS won't navigate
All the features on my Nokia 500 seem to work fine, except the Navigator. When i start the unit, it stays on the splash screen, unless I choose one of the other features from the menu. If I choose Navigator, nothing happens. Any ideas? I have tried, reset, reset to factory default, let the battery die, and reinstalled the maps from the cd already.
  • dallas893 Mar 23, 2009
    This worked fantastic - thank you soooo much! Glek you rock!
    This worked great - thank you sooooo much! Glek you rock!
  • 3 Answers
Suckthedick, lick the tip, grab my balls, swallow my gravy
Posted on Mar 15, 2009
The same exact problem happened to me. Go to the Nokia website, download their software update wizard and follow the instruction. It will flash the unit and fix the issue.
Posted on Mar 17, 2009
6ya staff
SOURCE:
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
Tip
These tips really doesn't work on my unit (nokia 6110 navigator).i've been...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Feb 09, 2009 | Garmin StreetPilot C330 GPS Receiver
2000 navigator won't shift into park
You may have a broken transmission mount take a look put a jack under the tail shaft out a little pressure on it you see it separate if it's bad ..I've also seen motor mounts cause that on rare occasions
Dec 16, 2017 | 2000 Lincoln Navigator
Nokia navigator suddenly cannot find any satellites
Did you disabled the data plan? If the A-GPS is disabled or not working then it takes quite some time for Nokia to detect the sat.
If you stay stationary for few minutes then the lock will happen.
Mar 07, 2011 | Nokia 6110 Navigator Cell Phone
Navigon 5100 GPS Navigator - Will Not Turn On
my tomtom Go 720 stays frozen. When I try to push the "I agree" button it stays frozen.
Mar 28, 2010 | Navigon 5100 GPS Navigator Handheld GPS...
The navigator 6710 won't work as a phone only the navigation switches on. When you switch it on the screen does not show the menu or the contacts. Noen of the keys work except the start for navigation.
amazingly the auto zoom in out is not a software problem.. it's hardware problem nd that's is why nokia is not getting in to help as its gonna cost it alot. the problem is that the upper portion has become touch sensitive. the acceot key , hang up key,the two selection keys and the navigation keys are made touch sensitive "delibrately" or intensionly.
Feb 03, 2010 | Nokia 6710 Navigator Cell Phone
How to use Route 66 GPS set-up in nokia 6210 phone. Have tried many times with no success. Very annoying. ta Bill
I think Route 66 was used in Navigator 6110 Navigator only and it was linked with phones IMEI code. The 6210 Navigator is equipped with Nokia Maps 2.0 and Route 66 isn't compatible I think.
Oct 21, 2009 | Nokia 6210 Navigator Cell Phone
Navigator on my nokia 500 doesn't work
Good news for users with the same problem- The solution is easier than you think :-)
When my Nokia 500 began to show the same issues that you mention here I quickly thought "What a waste of money and now here I am stuck with this useless device" but a little bit of research helped me find the solution; here you go:
Go to https://www.nokiausa.com/get-support-and-software/product-support/nokia-500 and follow the instructions there. Basically what you will be doing is to re-install (in some cases update) the software in your device. Once the process is finished, Viola! your GPS function will be restored (-;
Now, be aware that ALL your saved addresses will be gone, but I rather have that, than a GPS that is good for nothing.
Hope that helps guys!
Mar 14, 2009 | GPS
Nokia E65 Navigator
You need an external GPS device with the E65, which it will access via bluetooth. It has the navigator software, but no internal GPS.
You can use google maps and that will use the GMS tower ID's to give you a rough location of where you are.
Feb 16, 2009 | Nokia e65 Cellular Phone
Gps Stopped working (Uniden GNS 8431) and this message comes up on the screen- Fatal Application Error mobilenavigator.exe has performed an illegal operation and will be shut down. Program: Mobile...
You hopefully have the mobile navigator software CD that came with the GPS unit. Copy the entire folder and contents of the CD to your SD card (make sure you make a full backup copy of the exisiting software on the SD card first).
John MacLean
Brisbane, Australia
Aug 30, 2008 | Uniden GPS
Nokia N500 Auto Navigation Logo
2,014 people viewed this question
Top Nokia GPS Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Nokia GPS Expert? Answer questions, earn points and help others
