The printer spooler service is not running.
** Spooler Problem fixed **
I had the same Problem before and now I have it solved help of this follwoing article please click below and follow there
mentioned steps and get your problem fixed.
Click here to open solved Solution for this problem Spooler not working (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance –
Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance –
Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and
select Properties.
In the properties box that open the service status should
read “Started” if not click on start.
If it says the spooler is started click stop, wait till the
spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
SOURCE: 1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
SOURCE: hp laserjet 1022
It sounds like an issue with the spooler service on Windows.
You will have to download the tool kit to run it. It states for windows server 2003 but will also work on xp Her is the link fo rthe download:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9D467A69-57FF-4AE7-96EE-B18C4790CFFD&displaylang=en
here is a link with direction for running it on xp
http://www.windowsreference.com/windows-xp/how-to-clean-print-spooler-in-windows-xp2003/
When you run it it will ask you if you are sure you want to delete spooler files. clcik yes. When it asks if you want to delete USB monitor click on no.
Thisis the fix for the print spooler issue after you run the cleanspl.exetool and wipe out all the ports. You have to add back in the USB portmanually.
Run regedit. Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Print/Monitors.Look for a USB Monitor entry. Before doing anything else, backup theregistry entry by right clicking on "Monitors" and selecting "Export".Give it a name and locaction so that you can put it back if you haveproblems later. If "USB Monitor" is not there, add it by right-clickingon Monitors, New, Key. Name the new key "USB Monitor". Once added,right click on the new key and select New, String Value. Name the newvalue "Driver". In the right portion of regedit, right click on the new"Driver" value and select "Modify". Make the value data "usbmon.dll".If there is an "HPUMON" entry (or the like), delete it. Disconnect theUSB cable to the printer. Run the "scrubber" or clean utility, rebootthe machine. Reconnect the printer and install the driver software permanufacturer instuction. This fixed my problem. Good luck!
SOURCE: Printer Spooler Service not working
Reinstalling drivers usually fix this problem.
Reinstall drivers with printer connection cable unplugger, either using driver CD or download from the link below.
HP LaserJet 1020 Printer series - Download drivers
