When I am running my 3000 watt honda generator to my cabin, the generator will blow fuses in my stereo and surround sound.But at the same time doesn't seem to produce enough power for my light bulbs or power tools. The light bulbs are really dull while the generator is running. Could anyone give me some advice? Thanks
Hello dear, have you solved your problems? Generator problems are caused due to a lot of causes. Maybe you should ask for help from technician. Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
Try calculating the wattage of all the components you are trying to use with your generator. Include EVERYTHING including lights, stereo, refrigerator, oven, whatever. Why it is blowing fuses in your stereo is really unclear to me. I would solve the issue with the dim lights first. Go to your breaker panel and turn off everything you don't need. You may be drawing current in a circuit that you are not aware of.
Http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf
I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance.
You could spend a lot of money on maybe parts./
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
SOURCE: Honda motor runs fine but will not generate power
try this site:
http://www.endtimesreport.com/dead_gen.html
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
SOURCE: Hi, i have two honda
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
SOURCE: honda ex1000 auto idle control
check the spark erestor screen that is behind and in the muffler.
it gets plugged with carbon
