Question about Pioneer PRO-99 TV
Blue tint on rear projection tv
My pioneer pro 99 screen has a blue tint.
Posted by Mark Koen on
  • Mark Koen
    Mark Koen Mar 15, 2009
    factors listed in first response do not apply. please provide further help. the picture is clear, it just has a blue tint. please assist.
Anonymous
    Scholar:
  • 164 Answers
Hello there.
There are 3 bulbs inside blue,green and red. The blue tint normally means a fault with the red range. These TV's also have oil, yes thats right oil, through which the light travels, sometimes the oil becomes dirty and needs filtering or changing, though this should be done professionally. Hope this helps, please don't forget to rate me. Thank you.
Posted on Mar 15, 2009
Anonymous
  • 916 Answers
Hello. it might be as simple as a magnetic field near your tv.if you have any large metal things or speakers on top or next to yourtv try moving them about a foot away from the tv and see if that helps
Posted on Mar 14, 2009
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Dark screen on a pioneer SD-P403
By the desciption of your symtom, I think that you may have lost the blue CRT. You may want to call a local repair servicer to have the set diagnosed. It could be as simple as the video driver on the CRT board, or it could the the CRT itself.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 21, 2009 | Pioneer PRO-200 60" Rear Projection...
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
Pioneer pro 99
Remove the front speaker grille and access panel and you will see the CRts there there should also be a Sguare block with 6 buttons on it 3 on top and 3 on the bottom 3 are for focus and 3 are for Screens or [email protected] try turning the blue CRT down just a little see if that stops the blue with retrace lines. Let me know how you make out.
Apr 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Pro 99
Sounds like convergence outputs. Possibly some biasing resistors.
Mar 19, 2007 | Pioneer PRO-99 TV
Televison & Video Logo
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
