Hi
hope you can help, when i press the open button the front flip screen folds half down then switches off, it then after a few seconds closes comes on and then reopens itself and switches off again. This cycle repeats unless i switch open again to shut the screen before the system flips and switches off. PLEASE HELPPPP!!!!!!!! Any ideas??
There is a ribbon cable that connects to the main board that needs to be replaced the best thing to do is to have the radio sent off since the is tedious sodering involved unless you know how to repair these thing its pretty easy is to good of a head unit to go to waste the part cost about 33.00 including shipping go to pioneers web site and get the 800 number
I also had this problem and the solution was to change the data bus, or if you want, you can pull out a little the data bus.
I'm having the exact same problem with the face plate opening half way, stopping, powering down, powering back on, closing and repeating the same process over and over again. It will still allow me to listen to the radio as long as I don't try to open the face plate. I hope someone can help with this. It is very annoying. Thanks.
