GE Nautilus 24" Built-in Dishwasher Logo
Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus detergent cap will not open
GE Nautilus dishwasher detergent cap will not open
Posted by pgcrum on
  • gloriakc May 12, 2009
    I cannot get the detergent dispencer to close. and the door seems hard to get locked.
    My problem is the opposite..my detergent disperser will not close and the door has become hard to lock.
    I cannot get the detergent dispenser to close. and the door seems hard to get locked.
Anonymous
  • 170 Answers
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Posted on Mar 28, 2009
When/where on the washing cycle does the detergent cup open?
normal wash does not open, will open on pot scrub
Please rate this response with thumbs up thanks
The soap tray door won't open during the cycle.
just place the required amount of detergent on the door of the dishwasher and not in the detergent recepticle! problem solved
Soap does not come out of dispenser and gets hard.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
My dishwasher is making funny noise and leaves
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
1helpful
What keeps the main detergent cup cover shut until it opens during cleaning cycle?
there is a clip that holds the door down it ,is spring loaded to open at a determined time.
1helpful
Detergent cap
Thanks for the model number. On your particular unit you can only latch the unit in the off position. If it still does not latch, open the door and remove all thr screws you see. Normal seven of them. Now, split the door and take a close look at the locking mechanism. Did something come loose? Is the spring in tact...Play with it and see how it works,...then what must be done to repair. It is really a simple system and has been tried and tested for many years in the GE Dishwashing Units. Good Luck, Eric Campion
2answers
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Top GE Dishwashers Experts
Mike
David Shaub
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
