Question about Sharp R-1610 Microwave Oven
Best way to remove microwave fire residue, soot and smell...
I am trying to get the fire residue out of the inside top, sides, and some of the bottom of a microwave. Baking soda cleaned outside and around the inside of door nicely, but is not removing brown coloration from sides and top. Is this permanently burnt or is it removeable with something else. The microwave seems to work well.
Posted by patchesfrome on
  • Lynne Drazin Apr 11, 2009
    Burned a potato to a crisp. The microwave interior now has soot and the smell of fire...but it works. How can I best clean this, please???
Krissi Smith
    New Friend:
I did the same thing and nothing I've tried seems to help any more suggestions???
Posted on Aug 08, 2013
Anonymous
Use a scouring pad
Posted on Mar 14, 2009
My microwave is steaming and my whole house stinks. how do i stop the smell and is my microwave broken or is it alright to use?
I guess the question is, what kind of smell is it? Is it like rotten food? Is it like burned wires? If you are not sure, ask a friend to help you identify the smell. Any burned smell is telling you "Get rid of the machine RIGHT NOW before it catches fire".
Other smells that are not so bad can sometimes be helped with a good "airing out" and the addition of a pile or box of baking soda inside to absorb the smell. Do not turn the machine on with the baking soda inside. Air it out outside or in an area that is not living space.
God bless your efforts.
Jun 01, 2015 | GE Microwave Ovens
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
May 17, 2014 | Microwave Ovens
Microwave burn smell how to remove
put an ozone generator inside for 5-10min. Unplug the microwave, then run the ozone generator for 5-10min. IF that does not work you may need to start replacing plastic bits inside.
Mar 02, 2018 | Microwave Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    How do I remove burn smells from a microwave?
    Clean the interior with diluted bleach, and get a small box of baking soda "open top" and let it sit for a good 48 hours before use.
    Apr 03, 2012 | GE Microwave Ovens
    Burnt smell in microwave
    Hi Diane, that happened to me last year my daughter burned popcorn in microwave. I washed it out with baking soda and water, hot water. Then rinse it out good and place about a tsp. of baking soda in a small bowel with a little water set timer for 10 seconds on high power, this helps to nuetrilize the air flow and now you can use it with out any burn smell.
    Feb 22, 2012 | GE Microwave Ovens
    How do I get the burned smell from my Whirlpool microwave. All I did was overheat a biscuit. We've tried vinegar, baking soda, Fabreeze and lots of other stuff. Can you please help us? Thank you. ST
    Spray the inside with Dow Scrubbing Bubbles Bathroom cleaner, let foam, wipe clean, and rinse. Then if the odor persists, mix one part vinegar, two parts water in a bowl, set inside the Microwave and turn on for five minutes.
    Jun 15, 2011 | Whirlpool MH7135XE Microwave Oven
    Have a smell from cleaning solution I used to clean out microwave. Smell is still in microwave
    Baking soda is good at absorbing odor. Maybe you could sprinkle a generous amount on the bottom of the microwave and run it on defrost for about 30 minutes. If the odor seems to abate after this, repeat 'til you're happy.
    May 01, 2009 | Kenmore Microwave Ovens
    Burnt cinnamin bun with waxed paper on top
    Boiling water with baking soda then with vinegar seem to be the best tips.
    I would do a Google search for "microwave smell" and you'll find a ton of links.
    Nov 25, 2007 | Microwave Ovens
    Sharp R-1610 Microwave Oven Logo
    2,284 people viewed this question
    Top Sharp Microwave Ovens Experts
    Michael Thomas
    Michael Thomas
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
