Question about LG 42LC2D 42 in. LCD HDTV
On my LCD TV. a series of vertical colored lines scroll across the screen instead of a picture, however sound did play. What could this be?
Posted by sdove10018 on
marionbagget
  • 718 Answers
First you can try adjusting the cable to the LCD Controller (LCD CONTROLLER 6870C-0080D from LG 42LC2D) Sometimes the contacts get out of alignment and disconnecting/reconnecting it will clear it up. Do not touch the contact points.
If this does not work, you may have to replace it.
Posted on Mar 14, 2009
Anonymous
  • 3 Answers
Its problem of screen, replace it
Posted on Mar 17, 2009
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
I have 5 thin vertical white lines on the screen sound is fine.
It looks like the problem is comming from your LCD chips, they are starting to burn out and that is why you get this lines across your tv set, if you leave it like that the problem is only going to get worst
the lines will get bigger until it finally covers your whole screen you need to replace the OPTICAL BLOCK to fix this problem
good luck hopes this helps
please rate this solution !!!!!!!!!!!!!
Jul 05, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
980 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
