Question about Icom Radio Communications
Good day Gents i have a mfj299 microphone that I
Good day Gents i have a mfj299 microphone that I am try to wire to my IC775 ICOM 8pin plug the color code on the mice red,gray,black yellow orange green brown. does any one know where or what thes colors are identify ,like (white is audio ,red ptt? &etc thank u dutch email [email protected]
Posted by dutchman2u on
James Kouzman
    New Friend:
  • 14 Answers
I suggest you post this question on a Ham Radio web site.
Posted on Jan 26, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: motorola spectra
They are NOT for the speaker. Speaker wire is black "zip cord" with plastic connector coming off of control head connector. The Green and Orange are Ignition sense wires. How they are wired determines the power state of the radio, i.e. if to BATT radio will be on unless shut off, if to IGN radio will power up when ignition turned on.
Posted on Apr 20, 2008
Anonymous
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Posted on Sep 29, 2008
Anonymous
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
Anonymous
SOURCE: My T5530 don't transmit audio to another radio, you can hear the.
good am, if no audio, try to check the microphone if its ok? , if not, just change, if its ok, try the PTT maybe the switch is busted or need cleaning, most cases is the need to clean due to dust and moisture. just spray contact cleaning fluid. - DU7UV
Posted on Apr 09, 2009
Anonymous
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Jan 03, 2014 | Heil Sound Audio Players & Recorders
IC-M504 with a rear panel microphone jack-- what is the pinout?
ICOM or even HRO may be able to provide you with a schematic for that pinout.
Jun 04, 2012 | Icom IC - M504 Black Submersible PLUS...
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
Can the Microphone be replaced on a ICOM M302 Radio
The MIC is available with the cord from Icom or me (847-746-0100) It is not easy for the novice, it must be routed through the front panel and plugged in to the circuit board inside. Not impossible to do, just tedious. Also, my wild guess is about $50 to buy the mic, so, not worth it if you pay labor!
Jan 09, 2010 | Icom IC-M302 VHF Marine Radio
Radio Communications Logo
210 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
