Question about Kenmore Refrigerators
Leaking water from kenmore freezer to refrig below
We have a freezer on top frige. its been leaking water from the holes in the back top of the frige compartment for about two weeks. I can't figure out the model number of the appliance but it is a kenmore - med. size
Posted by tvierschilli on
Anonymous
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Posted on Mar 14, 2009
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Cannot find the drain hole in freezer compartment
Defrost the frige by unplugging it and let itsit for 6 hours open. remove the icemaker and rear panel inside freezer. drain is in the middle below coils. Look on the back of frige for the drain hose to help you locate the drain. It is hard to spot covered with ice but it is a hole about the size if a dime. Pour hot water thru the drain. It should drain down the tube to the bottom drain pan...
Mar 29, 2010 | GE Monogram ZICS360NRRH C... Bottom...
Leaking water inside from top back of frige ?
if your fridge has a cold wall system then on the bottom is a v shaped gulley with a hole in middle check this drian hole is not blocked.
Jun 06, 2009 | Whirlpool GR9SHMXLB / GR9SHMXLL Top...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Refrigerators Logo
248 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
