Question about Garmin nuvi 200W GPS Receiver
No Maps on My GARMIN nuvi 200W
I recently purchased a GARMIN nuvi 200W. I went to their website and registered it and did a map update...everything appeard to go as planned. After I turned on the unit there are no maps...what in the world can I do to restore the unit back to its original mode. Any advice is greatly appreciated.
  • 10 more comments
  • Anonymous Mar 15, 2009
    I have the same problem. I did not do anything to my unit, no up dates nothing just using it out of the box.I got in my car I turned the Nuvi 200w on it shows a screen that says "NO DETAILED MAPS FOUND THAT SUPPORT ROUTING.THE NUVI CANNOT BE USED WITHOUT THEM." That's all it says and I can't do anything with it.
  • Anonymous Apr 08, 2009
    I have the same error screen pop up, and it will not allow me to do anything like access menus.
  • Ann4x Apr 09, 2009
    Same problem here and their website is evidently jammed today, can't access mygarmin. There is a 30 minute wait via phone. Anyone have a good internet link regarding this problem?
  • Anonymous Apr 10, 2009
    this is annoying..... anyone got an answer? you CAN NOT access any of the settings because it is locked on the error window!
  • randerson6 Apr 11, 2009
    The exect same thing happened to my new Nuvi today. I searched the site and it has a fix. You have to create a new unlock code file. I did this and it still does not work. The' directions say that if this does not fix the problem, to call support, but alas, it Easter weekend and no one is answering!
  • 4chowdog Apr 12, 2009
    I have the same problem, No detailed maps found that support routing. I tried the "recreate the unlock codes file" but that did nothing. Have to wait till Monday to call support. From the looks of things, there is a problem with the download file they have on their website
  • dekoski_kurt Apr 13, 2009
    same issue here. did the update yesterday, which took approximatly 5 hours and then bang I get the error page and can't get beyond it.
  • Anonymous Apr 18, 2009
    Bought the unit and it worked fine out of the box. Downloaded map update 3 times now and still get can'y unlock map and NO detail on map when I open it bu holding the bottom right of the scree. I been in touch with Garmin TWICE and had their teck come into my computer and GPS and still have problem spent 8+ hours screwing around with this piece of **** so far and still have the same problem. Theu admittedly have a problem with loading the map of north america when the GPS comes preset not to allow canada without buying upgrade. Worthless piece of shat DON"T BUY IT !!!!!!!!!!!!!!!
  • fumed Apr 18, 2009
    I'm having the same problem! Spent 9 hrs trying to fix it & still nothing. I missed a once/yr event because of this! Taking it back for some other brand!
    A 24 hr help hotline would be nice!
  • neilinator5 Apr 20, 2009
    My nuvi was working fine and i even drove from NJ to Florida.
    I am going to try tex152's solution, but if it doesn't work I am going to return it.
  • bascombe2 Apr 22, 2009
    This is a total disaster.
  • Anonymous Apr 25, 2009
    Text152's solution worked great! just follow that = )
I bought the nuvi 200w and when I registered the unit it said that there was an updated map available so I down loaded and installed it. When I turned the unit on, it said no detailed maps available and would not work. I called garmin and they said that to fix it I had to hook the nuvi up to my computer and start>my computer>nuvi>garmin there is a file called gmapprom.img (shows over 1,000,000 mb) delete this file. Open all programs>garmin>mapsource highlight the areas on the map that you want and click on the add to device icon. After doing this, my nuvi is working fine. The explanation was that the original file had files for Canada that were not unlocked. Try this and good luck!
Posted on Apr 14, 2009
"Hi,
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards,
Richard."
That fixed mine. I tried for approx. 8 months and got no where until I found Richards post. My GPS works again!
Posted on May 24, 2009
Hope I am not to late. It took four days to get this out of Garmin and it works, just follow the directions to the letter and do not get impatient, when you are done it will work. Here is the instructions:
Thank you for contacting Garmin International. I am sorry that you are having difficulties updating your Nuvi. I have included a fix that you can do which will fix the error message that you are getting on your unit.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line ( add) " -build_map_image 006-D0783-04" at the end of setup.exe". For example it will look like this xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps.
10a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
10b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
11. The file is placed in subfolder named 006-D0783-04.
12. Copy the gmapprom.img file from the folder to the Garmin folder on your Nuvi. Overwrite the existing file.
13. The lower 49 states will be installed on the unit.
If you have any trouble with this fix, or are not comfortable trying it please call into our 800 number and ask to speak to Software Support and one of our technicians will be happy to assist you.
If you need further assistance please call 800-800-1020 number Mon - Fri 8:00am to 7:00 pm central time and someone will be happy to assist you.
Posted on Apr 22, 2009
Hello, I'm a 200W owner, I'll try to help;-)
When you go to Settings>Map>Map Info do you see any map installed? Is the map checkbox checked?
If after this you still dont have maps, probably you'll need a new map update from City Navigator or Mapsource (request it from Garmin) and be sure to check all map areas you would like to be installed.
Posted on Mar 18, 2009
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Jun 06, 2015 | Garmin nuvi 200W GPS
When trying to put in an address the Garmin asks me for a country and then does not accept it after typing in the first letter. The other functions appear to be ok.
Hello
you need to update your map
Purchase your map updates (if necessary). You can purchase map updates for your Garmin Nuvi from the Garmin website. There are two basic options: a lifetime purchase or a one-time upgrade. The lifetime purchase gives you access to any new updates for the life of your device, while the one-time upgrade will provide you with the latest current maps, but you'll need to purchase again if you want to upgrade again later.
Make sure to log in with your myGarmin account before purchasing the map upgrade.
You can download garmin express here
Apr 19, 2015 | Garmin Nuvi 610 GPS Receiver
I have Garmin Nuvi 200W that I'd like to add Australian Maps to.
You can purchase maps for download at https://buy.garmin.com/shop/buymaps.do?null&ra=true. Garmin does sell the maps for Australia at that site.
There are other maps available from third parties which are compatible but you'd have to confirm that from the seller.
Feb 19, 2010 | Garmin nuvi 200W GPS Receiver
This 200 series was purchased several years ago and was never registered. I need to update the maps so what do I need to do? I do not have the PC cord.
First you need to buy the correct USB lead that will connect you unit to your PC. They can cost upto £19 brand new.
Then you need to go to myGarmin and register your unit ID with the secure website. Because you will already have maps already on the unit you can buy lifetime updates for £99.
You may have to perfom an unit update prior to the map updates as you have never hooked it up the Garmin website.
Hope this Helps.
Oct 08, 2009 | Garmin nuvi 200W GPS Receiver
I need to update my garmin nuvi
u go to www.mygarmin.com, register the unit and then click updates, I assume you are talking about maps, if so the cost I think for the update is $125.00
I have this same unit, the cost of the new maps is more than I paid for the unit on Ebay.
Sep 18, 2009 | Garmin nuvi 200W GPS Receiver
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
How do i get a free map update for my garmin nuvi200w.it is second hand?
First you need to find out if there are any free updates available for you GPS. You can do this by going to www.google.com and typing in "free updates for Garmin Nuvi 200W" If there are any available you should find them here.
May 19, 2009 | Garmin nuvi 200W GPS Receiver
I purchased a Garmin nuvi 200 and registered it 12/22/08. I would like to update it on line. How do I go about it. I need a tech to help me. How to connect Garmin Nuvi 200 to PC (update maps)?
You can go to this website: http://www8.garmin.com/products/webupdater/howtoinstall.jsp which have option to download the free software that will check if you are able or eligible for the update. Just follow the instructions on the website. No Tech needed for this.
Jan 09, 2009 | Garmin nuvi 200W GPS Receiver
Product key for free download
i don,t have product key for nuvi 650 he say the key is in disc i don,t know thank
May 27, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
2,424 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
