SOURCE: need to find the fuse box and replace cig fuse
DOWN BY YOUR RIGHT LEG WHEN IN THE DRIVING SEAT THE FUSE NUMBER IS 32
20 AMP
SOURCE: I am looking for a
You should find what you need at the following address:
www.autoeducation.com/repair_manuals/Jaguar-S-Type.html
good luck.
SOURCE: car heating system sudnely stoped operating
Are you having trouble getting the fan to blow, or does it blow cold air? If cold air, be sure to first check the coolant level as this could cause no heat for the cabin, and can also cause expensive damage to your engine.
If the coolant level is good, it can be a number of things:
There is a control valve in the engine compartment that opens and closes to allow hot water to travel through the heater core. Check for proper operation of this valve.
Secondly, on some of the Jaguars, they were filled with a special coolant that is not compatible with off the shelf coolants. If normal coolant was added to the system without a TOTAL flush, then the two coolants would mix and cause a coagulation. This thickening would in turn plug the heater core.
Lastly, on some Jaguars, there is an auxiliary electric water pump in the engine compartment that pumps the water through the heating system. If this pump fails, then you would get a LITTLE heat once in a while, (especially when high revs, or on a warmer day). This pump is fairly expensive, (what isn't on the Jag), but easy to replace.
Good luck, and let us know what it ends up being.
SOURCE: Need owners manual for 2000 jaguar s type
to change the clock...press the menu button for a few seconds...then you will see ADJUST CLOCK..use the arrows to changs clock..
SOURCE: i know were the fuse
Hi.
Below diagrams for 1997-2006 fuse map. Click on the pictures to enlarge.
Due to maximum message length limit, I will post details on separate messages:
also in the trunk fuse box also has fuses not used tht are used and what are the black fuses in them too
