Question about Seiko 0512037FA Wrist Watch
Resetting a SEIKO watch
I have an old digital SEIKO battery-operated stainless steel man's watch. Is there a set of instructions on how to reset the date, alarm, time of day, etc?
Posted by gwspms on
Arturs Kalnins
  • 2,338 Answers
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
Anonymous
    Problem Solver:
  • 6 Answers
Hi, just visit SeikoDigitalWatches.com you can find almost any seiko digital and analog watch instruction guides from above site, otherwise check your Watch Picture and Model on RareDigitalWatches.com
Thanks
Kashif
VintageDigitalWatches.com
Posted on Apr 02, 2009
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
How do set alarm on my Seiko stainless steel water resistant 10 bar alarm watch?
Click on my name (escapement), then click on TIPS AND TRICKS. Browse through all and you will find the link to all SEIKO watch manuals. Rate me, please.
Jun 24, 2010 | Seiko Sportura SNJ007 Wrist Watch
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 | Watches
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Seiko 0512037FA Wrist Watch Logo
2,276 people viewed this question
Top Seiko Watches Experts
Marvin
Marvin
Gustavo Ortiz
Gustavo Ortiz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
