I just bought the coin op washer and dryer at an auction and cannot reprogram it for the cycle duration and amount of money I want to charge. Does anyone have any idea how to do this. I do not have a palm so i have to program it right on the washer panel. there is NO card slot either
Available at www.coinop.com, or call 1-800-643-3444
Also through Whirlpool Corporation Literature department and for selected Trade Partners at: www.whirlpoolwebworld.com, products and more commercial laundry link, or call: 1-800-851-4605
COMMERCIAL LAUNDRY APPLIANCES
SOURCE: Replacement For Whirlpool AWG329 washer/dryer
Not sure if this will help, but Whirlpool has a pretty neat tool that can help you configure your laundry-room layout: LAUNDRY-ROOM LAYOUT
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
SOURCE: whirlpool washer stops during cycle
Do a visual inspection on the electronic module. To do you need to removed it. Follow the manual for this. I got the manual from, it's pretty big, about 44MB: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/07e2c9ebdcf04a3085256f38004f9b84/$FILE/WPWASHER1.pdf
I had the same kind of issue on mine, no spinning and occasionally it did not want to start. I decided to remove "electronic control module" and do quick visual inspection on the board.
I find out that the board was full of little (microscopic) lead (plumb). I cleaned it with a toothbrush and ALCOHOL on both side, re-installed it and since then the machine worked find... Finally after a year I have a working machine.
I think you should test this solution before spending $400 on a new "electronic control module".
Let others know if it work on your side too.
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
