Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Uniden handet does not work
I have a Uniden phone with 2 handsets. The 2nd handset just quit working. No screen, buttons don't work. Completely dead. Does the battery need replacing?
  • 39 Answers
If you have had phone for about a year, yes.
Posted on Mar 18, 2009
  • GlenJordan Jul 11, 2011
    But if you put the battery from the dead handset into the live handset and it works, then, no. Why not test it when you have two handsets and you know one of them works????
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
Anonymous
  • 38 Answers
SOURCE: I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Posted on Sep 08, 2009
KingDWS
Dave King
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
snvirani47
  • 4 Answers
please help me to register additional head set
MODLE NO IS DXA 15588-2
Posted on Aug 11, 2010
I have a uniden 1480 the base seems to have quit working i have replaced it before is there something I can do to fix this
if your meaning by this statement that it no longer charges the handset , but the page handset button still works (proving the thing is not totally dead) then yes ive had great results cleaning the electric contact points both on handset and down in pocket on base that handset drops into , with a New pencil eraser (not a used one, graphite and all) just twirl it a few times on each contact till it gleams again , blow dust away, i'll bet it charges again
Aug 05, 2015 | Uniden Lands Phones
Phone handset screen is blank. It says Searching and when I press a button it goes blank.
Try unplugging the battery inside and reconnect it and put it back on the charging stand
Mar 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I turn offn the mute on my handset?
Press the CLEAR button just above the 1 on the number pad.
If you need a manual you may download a copy here.
Aug 10, 2012 | Uniden Cordless Phone
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
About a week ago we purchased a new cordless phone with a second handset for upstairs. It is a Uniden Dect 6.0. Without warning the 2nd handset's buttons ceased to function. It still receives signal but...
Try putting the 2nd handset in the base station for a few minutes. Sometimes this helps it reset.
Alternatively, just switch the handsets and see if that works.
Sep 06, 2017 | Uniden DECT2080-2 Twin Cordless Phone
No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Sep 29, 2009 | Uniden Cordless Phone
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
No dial tone at all
if the non-cordless phones are ok, it sounds as if the cordless handsets are the only ones not working, have you charged the batteries on those handsets ok and are there any signs if life, eg lights or on-screen messages ? Are they switched off ?
If there are signs of life, check the level of charge, if dead completely, take it/them to the main unit and put on charge for about 10 hours, if they work for only a short time and you have had the phones for a few years, then you will need to replace the re-chargable cells as they don't last forever and they are not holding the charge.
Hope this has given you some clues.....
Jan 16, 2008 | Uniden TRU8885-2 Cordless Phone
Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Jan 19, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
271 people viewed this question
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
