Question about Maytag MAV2755A Top Load Washer
Cloths are still very wet after spin cycle
The drum doesn't seem to be spinning as fast as when the washer was new and the cloths are still soaked when the cycle is complete.
Posted by mwilliams277 on
Anonymous
    Scholar:
  • 60 Answers
This sounds like a belt issue. A belt will become weak and stretch or glaze over time. Both of these conditions will cause a slow spin.
The belts are located on the bottom and are relatively easy to replace. Go to: www.repairclinic.com for info on removal and installation. You can even order a new belt from them.
Posted on Mar 14, 2009
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
My washer is making a clicking sound when it is about to begin the high spin cycle to spin the water out of the clothes and is unable to begin the spin cycle on it's own. I have to manually move the knob...
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
Nov 21, 2017 | Whirlpool LSQ9500L Top Load Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Maytag MAV2755A Top Load Washer Logo
Top Maytag Washing Machines Experts
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
