Question about GE Adora DVM1850 Microwave Oven
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Posted on Mar 14, 2009
If under waranty, use it. Otherwise, its probably the microwave (magnetron) tube, and it isn't worth fixing. Microwaves are usually cheap , so just replace it.
Check the heating element of the oven.
Mar 01, 2015 | GE Microwave Ovens
Sep 28, 2012 | Microwave Ovens
May 28, 2011 | GE Adora DVM1850 Microwave Oven
Nov 05, 2010 | GE Adora DVM1850 Microwave Oven
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 21, 2010 | GE Adora DVM1850 Microwave Oven
Jun 08, 2010 | GE Adora DVM1850 Microwave Oven
Jun 02, 2010 | GE Adora DVM1850 Microwave Oven
Jan 11, 2010 | GE Microwave Ovens
1,274 people viewed this question
